Question About A/C After Nelson Harness Install
I am not saying that the nelson fan harness caused this or anything of that sort. I installed the harness as directed and everything works as far as the fans but the A/C compressor doesn't work for some reason of course it is about 30 degrees outside but I figured it would atleast click on once. Does anyone have any idea as to why the A/C does not work please help? By the way that harness is pretty sweet I like the way it wires up everybody on here was right.
How do I change this text
I know it sounds dumb but is the A/C belt on. It took me a few months of owning my truck before I found wear my A/c belt is. but You have already checked that I bet. All fuses good? A/C compressor pluged it?
Will somebody please help me wiring diagram something please. This is driving me insane. From the test I have done so far the compressor is not getting any juice. Could this be in the tune (which I did) any input what so ever would be very helpful.
Did it work before the fans? Do the e-fans kick on? You tap into a green (I think) wire that is the 12V for the A/C clutch. Low on freon? If you aren't getting 12v to this wire has to be a fuse, connection, or a low freon condition I would think. Sounds like the PCM is commanding it. The idle up.
What year truck etc... Might be able to dig up a schematic. May be a relay in the loop.
If I am not mistaken the signal wire is a ground with a test light hooked to the postive post on the battery the test light lights up. There is a relay in the fuse panel under the hood. The A/C did work before the install, the fans also come on as I have them directed in the tune. I pretty sure the compressor will still kick on even if it is low of freon but I am not a A/C man. I still wonder if the way you set the pressure for the fans to cut on with the A/C on might have something to do with it but I am not real sure.The truck is a 2000 silverado with a 5.3. Anymore help you can give will be greatly appreciated.
