Put back to stock now truck runs like crap...
The truck had headers, CAI, and e-fans. We took all those off and put stock replacements. Now the truck runs like crap. When started the RPM's surge up to about 4k then drop down and idle is about 500rpm. It never used to be under 700rpm with the bolt ons. It is still using the mail order Wheatley tune.
I was just wondering if anyone has had this problem and is it because of the mail order tune? Perhaps stock parts aren't sufficient enough for the tune? It smells like it's running rich perhaps because now the air mixture is different (does that make sense??)
Any help would be appreciated...
FormerVendor
good stuff guys thanks for the info. that was my suspicions as well.
that also brings up another question. My brother-in-law is the one that took all the parts and he is putting the headers, CAI, and e-fans on his truck. What is the possibility that switching out his stock ECM with my tuned ECM would work? Only thing is his truck is an 04 5.3 escb 4wd and my truck is a 00 4.8 rcsb 2wd.
Just in case this is a no go...how much is a re-flash??
High on diesel fumes
Ok so I had Charlie put the PCM back to stock and I did the security relearn earlier this evening and the truck still runs horrible.
On startup, the engine revs to about 2500-2800rpm, then drops down low to about 500 and sounds like it wants to die. In neutral the truck with rev up to about 2000 rpms and stay there.
Highway speeds are fine and shifts are smooth it's just idling rough when in park or while in gear sitting at a light..
The only things we unplugged and plugged back in are the MAF and o2 sensors but those were never an issue before.
It just doesn't make sense that the truck was running great with the mods and now with stock parts it runs like ***.
Any ideas would be greatly appreciated..
