Ported TB, startup surge. Help!!
Old Feb 1, 2006 | 09:08 PM
Default Ported TB, startup surge. Help!!
I just installed a ported throttle body. I get a bad idle surge when i start it up then it settles back down after a few seconds. How do i make this go away?
Old Feb 1, 2006 | 09:11 PM
RoninsDenali's Avatar
My guess is the surge is caused by the learned idle settings and such from the old throttle body. I'd reset the PCM and let it go through its re-learn process with the new TB.
Old Feb 2, 2006 | 10:11 AM
Nick™'s Avatar
there is tables that can be adjusted for startup airflow and decay rates. if you are tuning yourself spend sometime with these tables or if you have someone tuning discuss the issue - make note of approximate air temp, engine coolant temp and how long the surge lasts
dsbodley
Nov 14, 2015 09:46 PM
gmcyukon
Oct 3, 2015 11:03 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
old motorhead
Sep 29, 2015 08:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
