Plot Filtering the VE
Old Nov 27, 2006 | 09:03 AM
desTRUCKtive's Avatar
Default Plot Filtering the VE
He on many if not all the tuning guides that are written it says avoid going into PE mode when tuning the VE in SD mode, and the reason for that is to avoid throwing in another variable that will adjust the fuel ( I think I am right). My question is can you plot filtering and exclude all those values that go into PE mode. Cause I was trying this and it works great.
But I am not sure if once you go into PE mode it will mess with the cell values that are not on PE mode. Maybe that is why people just say not to go into it.
Old Nov 27, 2006 | 09:14 AM
foff667's Avatar
LS1TECH Sponsor
yes you can filter pe mode out.
Old Nov 28, 2006 | 11:18 AM
dewmanshu's Avatar
Moderately Differentiated
post up your filter. I am curious.
Old Nov 28, 2006 | 12:05 PM
foff667's Avatar
LS1TECH Sponsor
commanded afr>14.6 & commanded afr<14.8 lol easy as pie
Old Nov 28, 2006 | 12:07 PM
foff667's Avatar
LS1TECH Sponsor
technically, in most cases you could just put in that it must be >14.6 & it will work just fine.
Old Nov 28, 2006 | 12:47 PM
02sierraz71_5.3's Avatar
why not just raise the tps and not worry about it
Old Nov 28, 2006 | 01:26 PM
foff667's Avatar
LS1TECH Sponsor
I know I generally don't feel that safe feeling when im at 5000 rpms and 80kpa running at 14.7:1...but thats me.
Old Nov 28, 2006 | 01:27 PM
I will once I get home. But I used TPS>95 and MAP>55kpa. I will show what I did on my scanner.
Old Nov 28, 2006 | 01:45 PM
foff667's Avatar
LS1TECH Sponsor
tps>95 wont necessarily get rid of pe mode ...it just means it will filter out wot basically, but depending on how you've setup your pe mode enablers you might still be able to go into pe mode for long periods of time.
Old Nov 28, 2006 | 02:09 PM
1slowsilverado's Avatar
Just use [SENS.121] >14.6
