PLEASE Help Bleeding abs Brakes
Old Jul 17, 2012 | 02:15 PM
flippindabird's Avatar
Default PLEASE Help Bleeding abs Brakes
Im sure this is a topic thats been touched on quite a few times, ive actually found quite a bit of info by searching the forums, BUT i want to know what scan tool is recomended and what is the process i need to go through once i have the scan tool in hand to get my brakes completely bled... i have bleed the brakes from longest to shortest line, i still have no brakes untill the pedal touches the floor, and then its not much brake at all anyway... ive been on this brake job with no transportation for 3 weeks... replaced EVERY line all 4 rotors and pads....
id really appreciate some help on this subject as i really dont want to take it to the shop because i dont have a scan tool, im willing to buy the tool, i just dont know what one works, and i dont know the process i have to go through to get this doen, if ALL of this info has been covered in another post, please link me, delete this post and disregard.
IF YOU PERSONALLY HAVE NOT SEARCHED AND FOUND ALL OF THE INFORMATION I AM ASKING FOR PLEASE DO NOT TELL ME TO "SEARCH" AS I HAVE SEARCHED AND THAT IS WHY I AM POSTING thank you for your consideraton in this matter
truck is an '02 silverado ecsb 4wd 5.3L auto no hydroboost(unfortunately)
Old Jul 17, 2012 | 02:19 PM
AndysC3's Avatar
You need a tech II to cycle the ABS pump. Im not sure if any other scanning software can do it. Or you could find a dirt road, get up to about 20 and slam on the brakes. that should activate the ABS and cycle the pump. Then rebleed the brake line. Make sure you keep a close eye on the reservoir and dont let it get below half full.
Old Jul 17, 2012 | 02:46 PM
TXSZ66AVLANCHE's Avatar
So what started all this? More details please.
Old Jul 17, 2012 | 03:04 PM
lol @ 20 on the dirt, got it, must make the pump work hard... someone justb told me to pull the plugs from the abs and bleed it... that work?
Old Jul 17, 2012 | 03:16 PM
AndysC3's Avatar
I say 20 because your brakes are barely working now. You dont need the pump to work hard. Just enough to cycle to get the air bubbles out of the system.
Old Jul 17, 2012 | 03:27 PM
Lloyd-TX's Avatar
Most likely you need a new master cylinder . . .
Old Jul 17, 2012 | 04:10 PM
^YES brand new master cyl
was driving and came down a hill... brakes went out.... was a broken line, replaced, other lines broke, replaced them all.... no pedal pressure replaced master cyl... now no leaks no pedal pressure and no brakes.... bled 2x the conventional way and no brakes so i looked on here and found "need scan tool to cycle abs unit" and here we are
Old Jul 17, 2012 | 04:16 PM
AndysC3's Avatar
did you bench bleed the new master cylinder
Old Jul 17, 2012 | 07:40 PM
1FastBrick's Avatar
Custm2500's Rude Friend
X2
If this wasn't done then you most likely damaged the new master cylinder.
As mentioned you will need a factory Tech 2 or an aftermarket scan tool that supports that capability.
Old Jul 17, 2012 | 07:59 PM
06murder's Avatar
Abs sensor maybe going bad..
