Please HELP with AEM Wideband install!!!
Old Jun 29, 2006 | 06:45 AM
TravisH's Avatar
I always knew red was power but there are just so many of them and I had no idea how to trace it from the fuse to the wire... I see a fuse that would work, then I looked at the back of the fuse box and become lost again..when I get home from work today I'll work on it again.
Old Jun 29, 2006 | 08:21 AM
GMC_DUDE's Avatar
I am also installing an AEM wideband, although in a different configuration, and have a question. How are you running the wires through the firewall? I looked all over and could not find any openings.
Old Jun 29, 2006 | 10:18 AM
12secSS's Avatar
I use the AEM to tune vehicles all the time. Yes, you can replace the front stock O2 sensor with the AEM sensor. AEM provides the blue wire to simulate the narrowband O2 voltages (0V-1V), here is what I recommended on the HPTuners forums. This should help you as well, good luck!
Originally Posted by 12secSS
You will need to purchase a cigarette lighter adapter (like from radio shack) and connect the power and ground wires to it. Next you will use the white wire (not the blue wire) to hook up to the HPTuners E I/O. The AEM sensor can replace the stock O2 in the LT, then simply connect the harness. As for the signal to the ECM, run extra wire from the blue lead of the AEM to the O2 sensor connector. I forget which one, but having an extra O2 sensor connector will help connecting up. Plus you will not need to cut up your existing one.
Oh, reference this for the narrow band hook up:
http://www.audiohelix.com/tuning-documents/lc1/lc1.htm
HPTuners has a pre-configured input PID for the AEM, you'll see it when you add the E I/O PID. Good luck, you will be happy with it!
__________________
George P. Lara: 2001 Camaro SS #0391
HPTuners for '98-'02 F-Bodies & '99-'02 Trucks
Jenibella Racing Crew Chief
1998 Camaro Z28: 9.94 @ 137, 1.45
Old Jun 29, 2006 | 10:11 PM
TravisH's Avatar
I got it all done and working great! Thanks guys.
Now my only problem is that it is pig rich..
GXPJAY
Feb 13, 2022 08:15 AM
Dirtywhite
Aug 5, 2015 04:10 PM
zblee
Aug 3, 2015 03:45 AM
slowlsx
Jul 13, 2015 04:18 AM
