Picking up a Diablo Predator tommorwo
Old Nov 2, 2009 | 08:06 PM
  #21
viciousknid's Avatar
Where's the Beef?
if you are wanting to learn to do it yourself, why would you get a handheld?
that isn't the same as tuning yourself.
You can get a Used EFI Live for about the same as a Predator if you check around. The handheld is going to limit what you can change while real tuning software is basically only limited by your abilities.
Old Nov 2, 2009 | 08:08 PM
  #22
Aquinosteven's Avatar
I would but i got a Mac book. Trust me, I would spend all day messing around learning about all the different parameters but i guess this will do for now
Old Nov 2, 2009 | 08:18 PM
  #23
Where's the Beef?
Oh. Yea I dunno where they are on making it Mac compatible.
Old Nov 2, 2009 | 08:21 PM
  #24
The day that EFI live come out for Mac, I will be very happy haha
Old Nov 2, 2009 | 10:27 PM
  #25
catalac's Avatar
Registered User
Man the diablo haters blow me away, I have had several and they work great. You can dial in as good a tune as a canned custom tune if you read up a bit on adjusting parameters. Plus you can return to stock for service or resale of the vehicle and tuner. I bought my last one for 52bucks used off ebay, works great.
Old Nov 3, 2009 | 07:02 AM
  #26
06MonteSS's Avatar
FormerVendor
yeah, you will gain about 20hp/tq, plus better throttle response, acceleration, etc etc...
get your fueling dialed in and you will gain even more throttle response, acceleration, stronger/harder pull, and better mileage...
are you buying it brand new?? (concoursdirect.com has them for $299 new) if so, you will be getting one of the new versions that will allow you to save data logs. you can do some logging to see where you're average LTFT's are at, and adjust your injector slope based on that data....
here's a write-up on how to do a proper data log, what parameters you need to log, etc etc...
http://diablosport.com/index.php?nam...iewtopic&t=917
I see you mentioned that you have a MAC?? well, you're going to need to Run Windows on the MAC in order to use any of the diablo software - since it's Windows-only.
you'll also need to get the pc interface kit - which is the power adapter and serial/usb cable that allows you to connect the predator to your computer, so that you can download data logs, import/export tune files, update the predator, etc etc.
custom tunes can be done via email for very reasonable costs - you can PM me about it if/when you get to that point where you want even more performance out of it...
Old Nov 3, 2009 | 07:08 AM
  #27
yeah im buying my new from a local place. I wish I knew about that site. I could have saved my self $40. Im going to pick it up in an hour and i cant wait. Truck is filled up with 93 and ready too.
Old Nov 3, 2009 | 12:03 PM
  #28
So i installed the tune in the parking lot then disabled the TCM and set the injector slope to -2. Nothing performance wise has changed, AT ALL. From a stop, from a roll nothing. Same truck, different shifting. So im pretty pissed that i spent $340 that just changed the shift pressure.
Old Nov 3, 2009 | 12:58 PM
  #29
06MonteSS's Avatar
FormerVendor
which tune did you install??
are you sure it installed???
you would notice a difference for sure....
Old Nov 3, 2009 | 01:04 PM
  #30
I installed the Diablo tune
