PCM swap
PCM swap
i have a 6l and 4l80e in my '03 truck. For some reason the pcm won't get a reading from the rear VSS. The wiring all the way to the PCM and the sensor check out good. Can i swap in the computer from our '06 2500 shop truck and just load my tune on or is there something else that won't jive? thanks
Original pcm was the stock one, '03 chev 1500. I swapped the vss with the transfer case shaft speed sensor(same sensor, same reading) - shaft speed still registers, vss still does not. I also took a resistance reading off the vss and then took a reading from the two vss wires right at the pcm plug, with the sensor plugged in, and the two were the same. To me this would say that the whole circuit is fine up to the pcm?
Suburbazine
08-09-2015 01:17 AM
GreyChevy
07-07-2015 08:57 PM
