Pcm/harness questions
Old Apr 11, 2016 | 09:38 PM
fullboardmax's Avatar
Default Pcm/harness questions
I'm swapping a 00 6.0 into my 03 Silverado. Going from a 4.8 t56 combo to the 6.0 with a 4l80e. The trans harness is cut from the t56 swap. Is it possible to swap the harness and pcm from the 2000 into my 2003? Going to drive by cable in the process. Or do I just find a uncut 03 harness?
Old Apr 12, 2016 | 12:23 PM
Any insight at all guys? I have found information saying yes everything will work. Then more information saying no it won't.
Is there any benefit to going drive by cable? I assume the cable is nearly trouble free. Read something about better resolution with going speed density and using the cable. Anything to that? Thanks in advance for any insight.
Old Apr 12, 2016 | 08:19 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You can NOT use a 99-02 engine harness in an 03 up truck and ViceVersa.
There is actually a few small differences in 99-00 Vs. the 01-02 engine harness for the charging system but it can be changed in the tune.
Old Apr 12, 2016 | 10:26 PM
Thats good to know. Would the pcm be interchangeable?
Old Apr 13, 2016 | 06:19 PM
1FastBrick's Avatar
99-02 interchangeable
03-07 classic interchangeable
Just need the correct operating system in there.
Old Apr 14, 2016 | 07:02 AM
Last noob question. The harness is 99-02, 03-04, 05-07 classic correct? Im looking at a couple on ebay. Just dont want to buy the wrong harness. Starting to think it might be easier to just rewire the trans plugs.
Old Apr 14, 2016 | 12:34 PM
1FastBrick's Avatar
I believe the engine harness is basically the same from 03-07 classic.
07 was the split year for production so GM calls it classic if it's GMT800
The tac module and pedal changed in 06 and is different from 03-05 model.
gravedigger472
Jan 30, 2022 12:40 AM
mcconditioner
May 4, 2016 02:18 PM
lsxmalibu
Apr 19, 2016 02:01 PM
jbaum02
Apr 10, 2016 09:39 PM
