PCM & BCM questions...
Old Jun 6, 2015 | 03:54 PM
10 Second Club
Default PCM & BCM questions...
I intend on using the PCM from my 2000 in my 2001 when I swap over the drivetrain. (The PCM is already tuned for the cammed LQ4/80E & efans) Would it be a good idea to swap in the BCM from the other truck as well?
I'm installing the fog lights from the 2000 as well, most say that the BCM will need to be reprogrammed since my 2001 didn't come with fog lights. If I swap in the BCM, will that eliminate the need for that?
Old Jun 7, 2015 | 12:10 AM
1FastBrick's Avatar
Custm2500's Rude Friend
The BCM and the PCM Vin need to match for the VATS.
How ever when You you use different modules from another vehicle, The correct vin for your vehicle will no longer be in that vehicle. This could pose a problem for Inspections where the OBD2 port is used to read the data. For example a smog check. If the vin number does not match the one on the vehicle it could fail.
Old Jun 7, 2015 | 01:58 AM
10 Second Club
Is the VATS module something easily swapped as well?
Not worried about emissions, none here in FL. I would fail the visual if they did. (No EGR)
Old Jun 7, 2015 | 09:10 AM
George C....'s Avatar
Formerly ScreamingL
the later yr pcm is a better processor, id use that one
Old Jun 7, 2015 | 09:14 AM
10 Second Club
The 2001? I checked and it's the same part # as what came out of my 2000.
Old Jun 7, 2015 | 09:26 AM
Formerly ScreamingL
01 and 02 are a far better pcm then the 99-00 pcms
Old Jun 7, 2015 | 01:27 PM
10 Second Club
The PCM I took out of my 2000 has a service # of 09354896, HDW # 16220610. I was expecting it to be a 411 PCM.
Old Jun 7, 2015 | 01:31 PM
Formerly ScreamingL
99 and 2000 no matter what vehicle it is out of arent the same as 01-02 pcms
some of those earlier pcms can be flashed with the new operating system and some cant
when possible use a 01-02 pcm
part numbers dont change the fact of what is inside them
Old Jun 7, 2015 | 02:12 PM
10 Second Club
OK, I guess I will just have my current tune flashed onto the factory 01' PCM. I'll give the PCM out of my 2000 with the 4.8/60E when I take it out in a few months.
cheyenne383
Nov 13, 2015 09:24 AM
Wrecker 426
Sep 30, 2015 09:39 PM
kalikid06
Sep 20, 2015 07:46 PM
muncie21
Sep 7, 2015 09:55 PM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
