Passing Emissions & Tuning
#23
The car has an extra O2 bung that gets me failed even though I can show all factory sensors in place. I have to plug in a dummy sensor and make it look like it goes somewhere. Some inspectors will fail me saying I have extra sensors. When it is plugged in. When I cap it I get failed because I am missing sensors. The car has a cat. Some inspectors will say it isn't factory so you get failed. Some will say that cat doesn't count because it is a racing cat. Some will say oh well you need two of them. Some inspectors will just not pass aftermarket exhaust for whatever reason.
One guy tried to fail my truck because he saw a fleck of soot at a joint in the exhaust and said it leaks. Usually the truck doesn't get picked on as much as the car. The truck also has extra O2 bungs though. One time I did get failed because it is an SUV and the pipe has to physically go past the bumper and mine was a couple inches too short. The guy said exhaust could build up under the vehicle and kill me. This same dumb *** was running the truck in a garage with all bays closed because it was cold (during the winter).
#24
Many counties in VA don't have emissions. But technically you would need a cat to pass safety inspection anywhere in the state though. I have cats on my truck and on my car. Both vehicles get failed and passed depending on the inspector. Both vehicles have 0 codes, pass all readiness, and zero cheats/hacks.
Time to find a friend.
#25
100% Redneck
Wow Virginia is getting to be like Commieforina.
When I was in NC quite a few years ago I was failed for co2 levels on an old 318 Chrysler Cordoba. Was told maybe an oil change would help. The next test it was better but still failed. Got home and loosened the carburetor and pinched a broken off butter knife, hidden between the carb and manifold. On the drive to the station it would barely run with it sucking so much air leaning out the mixture. Pulled it in, the tech put the sniffer in the tailpipe (yeah that long ago) looked at his readings with a frown. He proceeded to check all the vacuum hoses for the conspicuous leak. The motor was shaking the whole car as I had my fingers crossed. Rolling his eyes applying the new sticker to the glass "I think you may have a vacuum leak"
#26
I'll have everyone know I failed spectacularly. While all monitors were good to go, they looked too close at my long tubes and after market cat setup. My emissions inspection was more intimate than a prostate exam. They put my Yukon on a lift to fully inspect! My stock ypipe and cats were toast so a new one is in the mail. Back to stock for a short while.
Ahh well, its the game we play!
That's crazy, i'd try another shop before putting tons of work in. I've worked in shops for 20 years and never seen an inspector go that hard. Most do it the laziest way possible.
#27
Custm2500's Rude Friend
California is the strict state in the united states on smog laws. A lot of other States are adopting California smog laws.
Take a closer look at the rules in your state. In california, a technician may not put the vehicle on a lift to inspect it for emissions equipment. It has to be inspected just as its driven in. They are allowed to use mirrors to see under it and around the engine. But they can not put it on a hoist to do so.
Now that you failed and your flagged in the system with modified parts, your basically already screwed any way.
#29
Aaaaaactually he asked if I wanted to be failed so the "guy" I bought my yukon from would be forced to fix it. *cough* I said noooo thanks.
Header removal takes me an hour. Same for putting stock manifolds and ypipe in. I needed an excuse to swap out my poly engine mounts that my wife hates anyways. Much easier without manifolds in.
#30
