Partial Throttle Shift Points
Old Sep 6, 2008 | 10:16 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
Yeah, the TCC I have set (now) not to lock WOT and only over 50mph in 4th. New Converter coming and I was thinking of letting it lock in 3rd. under 50% TPS similar to stock.
Dusty...think about this for a sec. I have the correct gear and tire size entered into the "speedo" section therefore speeds I enter into the PT tables will be correct, right? Stay with me bro...the actual rpm cannot be the same as stock. For me to go 60mph with 30.5/3.73 I will turn higher rpms than 31.7/3.42
Old Sep 6, 2008 | 10:19 AM
Stoichiometric's Avatar
In your tables that shift by mph your rpm will be higher. If you wanted to shift at the same rpm as stock you would need to lower those 15% or whatever the difference is.
Old Sep 6, 2008 | 10:24 AM
trever1t's Avatar
^^ yeah, i did that, lowered them by 10% but didn't like it...the 2-3 came on too early so went back up to the higher rpm. Weird huh?
Old Sep 6, 2008 | 10:28 AM
Wilde Racing's Avatar
How do I change this text
yes but hptuners will AUTOMATICALLY account for the gear/tire change. (as long as you have the "yes" checked under auto scale in the speedo section)!!!
Old Sep 6, 2008 | 10:37 AM
I think we are talking about different sets of tables and not know it. The tables that shift by mph will be corrected when you change the tire/gear. The tables that shift by rpm will use the same correction to the mph enable. If Bill used to shift 3-4 at 60 mph with stock gears he might have been spinning 2000rpm, with new gears/tires that shift at 60mph will need the engine to spin 2300rpm. If Bill still has a 4l60 I wouldn't worry about it because he is lucky if it shifts at all.
Old Sep 6, 2008 | 10:57 AM
we don't have part throttle shift point with rpm. only mph, tps, and gear..
I agree, Bill you are luck the 60 shifts at all! Don't look a gift horse in the mouth...
Old Sep 6, 2008 | 11:00 AM
I don't have part throttle shift point by rpm either, lol. I was thinking about wot.
Old Sep 6, 2008 | 11:03 AM
trever1t's Avatar
lmao....both of you kiss my butt!
Old Sep 6, 2008 | 03:18 PM
I agree the wot shift point would have to be changed
What?
Old Sep 9, 2008 | 09:16 PM
BaddillaK's Avatar
I did a lot of tweaking to mine especially on the normal(daily driver) mode and it made a real difference in the feel... I felt that the stock settings had it shifting into 4th to early on light throttle. how different are your normal/performance modes?
