Park Assist Off
Old Feb 26, 2012 | 12:39 PM
Lucille's Avatar
Default Park Assist Off
Anybody know what would cause the DIC to show "Park Assist Off"? It will usually occur after 15 minutes steady throttle driving time and results in about a 300-500 rpm drop for the same throttle position. No codes are set when this happens but it's driving me nuts.
Old Feb 26, 2012 | 12:45 PM
ak2007r6's Avatar
The park assist is the back up sensors right? I had a 2077 Avalanche do the same thing to me and it ended up being a bad sensor in the back. Go check all the connections and make sure they are tight and looking good.
Old Feb 26, 2012 | 01:55 PM
Lucille's Avatar
What could this system be tied to that would cause the rpm drop? I understand how a bad throttle body/tsp caused the Traction Control and Stabilitrac to light up the DIC, but this just doesn't make sense.
Old Feb 26, 2012 | 01:57 PM
ak2007r6's Avatar
I would try and get a shop to read the codes when it's doing it if you can, maybe they can help narrow it down. Not sure what would cause the drop in RPM's, that's kind of odd
Old Feb 26, 2012 | 10:47 PM
Lucille's Avatar
The problem is it doesn't set any codes. It makes sense to me that a TPS problem would light up Traction control/Stabilitrak, but I can't figure out what system would light the Park Assist Lights. Based on timing I almost think it relates to transmission temperature or the converter.
Aaron Arceneaux
Dec 21, 2015 02:54 PM
Jordan927
Nov 10, 2015 02:47 AM
Tigger Welder
Oct 1, 2015 08:41 AM
01silvy
Sep 26, 2015 10:20 PM
Velocity1
Sep 22, 2015 01:32 PM
