Im Having The Same Problem But I Have Both The Knock Sensor Codes
I have seen the wiring harness get so bad that it causes both knock sensor codes, also have seen BOTH knock sensors get corroded from water intrusion and cause the codes, thats why I generally replace both sensors and the harness while I'm under there. You could always check the connector to make sure its good and tight, its a 2 wire connector on the drivers side towards the rear of the intake..it clips onto the intake.
