P303 random misfire code #7 cylinder!
Old Sep 18, 2010 | 12:46 AM
juicedsierra's Avatar
Registered User
Default P303 random misfire code #7 cylinder!
If I let my truck idle for a few minutes it throws the check engine light, I hooked my programmer up to it and it said it was a random misfire and then I pulled up the graph and showed the #7 cylinder was misfireing, you can tell truck doesn't idle smooth and doesn't run like it should and its drinking gas real bad I never had any problems, it all started after I broke the pinion yoke and driveshaft, I put the 150 pills in it and I went 8.71@83 then on the way home the pinion yoke broke and driveshaft broke when I got it out of the shop I could tell it wasn't running right and since then just been getting worse and worse any help would be very much appreciated!!!
Old Sep 18, 2010 | 10:55 AM
Gordy M's Avatar
did you check the spark plug wire for #7? It happened to me once, several months after I put on headers.
Old Sep 18, 2010 | 10:57 AM
00ChevyScott's Avatar
Wearin' da big hat
Pulled the plug yet?
Old Sep 18, 2010 | 01:53 PM
Registered User
Changed plug, still has a misfire not as bad but still has it, I retuned it back to stock and just made it right for my gears, another thing I heard is a big vibration can mess with the crank sensor which can cause a misfire so I'm thinking it could be that when my pinion yoke and driveshaft broke it was a loud boom so maybe it knocked it out of whack? Or time to build a 8.1 !!!! Lol
Old Sep 18, 2010 | 06:22 PM
Registered User
Ok thought it might be the crank position sensor but was told truck wouldn't run if it was bad so now I was told could be the idle air control vavle but I did unplug my mass air sensor and it didn't effect anything still idle the same??????
Old Dec 13, 2012 | 11:50 PM
TexasGMC08's Avatar
Wondering if you have figured out your problem on #7 cylinder??? I am having the same problem but im getting a P1174, P0742 codes.
00loudchevy
Dec 3, 2015 05:54 PM
Avalanche2002
Nov 30, 2015 07:31 AM
bearden86
26
Nov 15, 2015 03:58 PM
Velocity1
Oct 2, 2015 08:01 AM
sTNT971
Sep 26, 2015 04:22 PM
