p1133 and p1153 help
Old Mar 13, 2009 | 05:38 PM
POPO1984's Avatar
Default p1133 and p1153 help
Ok ihave read a lot of posts on this problem when having long tubes. I think I am going to try and wrap my headers. Charlie is gonna do. Retune for me and delete the reports but what I have not seen anyone else sreport is that the idle is horrible...... my idle goes from about 400 to 700 constantly at every stop. Sometimes I can feel the surge while under light acceleration. Anyone else experience this... also I can feel a noticab le loss in power. The only new mods I have are stall and servo but I drove for 2 1/2 weeks before this problem arose
Old Mar 14, 2009 | 02:58 PM
budhayes3's Avatar
PT's Slowest Truck
Do you have access to a scan tool or any form of scanning software? Maybe there's an actual problem with one of the O2 sensors, or an exhaust leak causing un-metered air to enter the exhaust stream. I'd also check for a vacuum leak and make sure the air intake tube is tight.
Old Mar 15, 2009 | 09:25 AM
POPO1984's Avatar
i dont have access to a scan tool. these are the codes that onstar said was showing. im going to check for an exhaust leak. i know there arent any at the engine maybe at the collector but i dont remember where my o2 bung is on these obx long tubes. any ideas on common vaccum leaks
Old Mar 15, 2009 | 12:20 PM
POPO1984's Avatar
Ok I have fixed the idle problem. i had a loose intake tube. i dont know how it got loose bt it was. idle is good now just have to get charlie to delete the error reports. then i will get to my next set of mods. From searching on ls1 tech everything will run fine with the error reports deleted and it will still go to closed loop.
Old Mar 15, 2009 | 04:00 PM
budhayes3's Avatar
PT's Slowest Truck
Cool deal man, glad it worked out to be something easy. And I believe that you are correct, those error reports can be deleted without any harm.
1TRUESS
36
Feb 14, 2009 10:52 PM
FarmerBeau
28
Dec 22, 2006 05:11 PM
FarmerBeau
Dec 6, 2006 05:55 PM
v8
Nov 27, 2005 08:06 PM
low99silverado
Nov 20, 2005 07:25 AM
