P060 code?
Old Nov 2, 2005 | 02:34 AM
TurboGibbs's Avatar
Default P060 code?
Can anyone tell me what this is? I can't find it anywhere?
Old Nov 2, 2005 | 02:44 AM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Found this you sure its just P060
http://www.geocities.com/dtmcbride/h...bd_dtc_gm.html
Old Nov 2, 2005 | 02:46 AM
1slow01Z71's Avatar
also found this
copy paste: P0580 P0600 Serial Communication Link Malfunction
from this link
http://www.geocities.com/dtmcbride/h...c.html#generic
Old Nov 2, 2005 | 06:33 AM
TurboGibbs's Avatar
My Aeroforce Scanguage says 0060. According to the instructions, if the first digit is a 0 then replace it with a P. I've received the code 3 times in a week. It comes back every time. Maybe I'll stop by the parts store and get them to run the codes for me.
Old Nov 2, 2005 | 07:30 AM
Fogle07's Avatar
i got the same thing cody said
http://www.autotap.com/codes.asp
Old Nov 2, 2005 | 10:54 AM
Mort's Avatar
Cool
I ran P0060 through my AutoEnginuity and got
HO2S Heater Resistance( Bank 2, Sensor 2 )
Old Nov 2, 2005 | 11:06 AM
Scott Mills's Avatar
Will your AutoEnginuity do Crank Position Relearn? I have been looking at that hardware/software.
Old Nov 2, 2005 | 03:59 PM
Mort's Avatar
Cool
I don't think so. I am pretty sure that is beyond it's capabilities at this time. Supposed to be adding Wideband O2 in the spring though. I think all it can do is delete codes and turn the SES light off. Works well for data logging though and that is what I mainly got it for. I think it will also work to initiate some sensor tests but I have not bothered to try that out yet.
Old Nov 2, 2005 | 04:43 PM
TurboGibbs's Avatar
Thats probably it. Thanks.
Old Nov 3, 2005 | 09:01 PM
doublenot's Avatar
I'm pretty sure this HO2S Heater Resistance( Bank 2, Sensor 2 )
is what it is. After removing my cat's and 02 sensors I got this code and p0054 which is heater resistance bank 1 sensor2.
