P0405 & P0332 after 80e swap
Old Jun 4, 2012 | 04:03 PM
heartbeatpower's Avatar
Default P0405 & P0332 after 80e swap
P0405 - Exhaust Gas Recirculation Sensor A Circuit Low
P0332 - Knock Sensor 2 Circuit Low Input (Bank 2)
This appeared right after my 4l80e swap, thinking I pinched the wires. Seeing if anyone knows if it is in the same harness as knock sensors.
Old Jun 4, 2012 | 04:19 PM
nonnieselman's Avatar
on the 2002 the EGR splits off the passenger side of the last injector in the front.. but then again a 2002 with EGR? I thought they stopped that in 2000 or 2001?
Knock sensors are split off with the MAP i think, up on top but follows the driver side of the engine.. if you pinched that wire you have problems..
But the wires from that connector loop behind the intake manifold, it is possible to pinch it behind the cam and oil pressure sensors.
Old Jun 4, 2012 | 06:04 PM
06murder's Avatar
Knock sensors are under the intake and map is on top of intake...try an clearing them if they come back might have replace them
Old Jun 4, 2012 | 06:05 PM
06murder's Avatar
Have the tuner delete the eg r:p
Old Jun 4, 2012 | 07:59 PM
That's what I was thinking but why the code still!? I'm just going to check voltage to the sensors, if voltage is there then it has to be sensors themselves, I just dont see how they would go like that.
Why would I have to replace them If it never had the codes before the swap? It sounds to me more of a wiring problem. Its not map I'm having trouble with, it's EGR. Thanks to the both of you for help.
Old Jun 5, 2012 | 12:45 AM
I had a reflash for the 80e programming so maybe they loaded the wrong tune for a truck with EGR?
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
05GMC4.8
Aug 7, 2015 09:55 PM
iregret
Jul 27, 2015 10:32 PM
alex226
Jul 16, 2015 10:55 AM
JordanH
Jul 14, 2015 03:46 PM
