P0300 & p0200 dtc
Old Jun 27, 2011 | 09:09 PM
static06's Avatar
Default P0300 & p0200 dtc
motor is a 4.8 with 114,xxx miles
well started about an hr and a half ago. started the truck up everything was normal then i turned it off and went to fixing my reverse and turn signal lights. turned the key forward (but not on) to check the reverse and they were good. and i did have the parking brake on when i put it in reverse just in case. went and turned the truck on and it was completely different. rough idle, CEL flashing. took the truck up to autozone and got those codes. ill be checking my spark plugs and wires here in a min. and this is the FIRST time its ever thrown a code before
Old Jun 27, 2011 | 09:37 PM
Mangled03gmc's Avatar
Baltimore Whore
The 300 is a missfire code, the 200 is injector related, voltage code.. Make sure all the plugs are good on the wires, on the coil packs..
Old Jun 27, 2011 | 09:58 PM
static06's Avatar
yea im familiar with the codes. the spark plugs and wires are all good but im sure there well over the recommended mileage that there supposed to be changed out.
now i had the truck running and i was unplugging each injector connector starting on the drivers side and 1, 3, 5 and 7 injectors didnt effect the idle, but the 2, 4, 6 and 8 injectors really effected it. it made it worse. so idk im thinking it might be the spark plugs but then again the passenger side injectors
Old Jun 27, 2011 | 10:46 PM
Wilde Racing's Avatar
How do I change this text
If little or no change was noticed while un-plugging 1,3,5, and 7, The problem is with those cylinders, NOT the passenger side. the fact the passenger side made a change proves those cylinders are contributing to the global cause of truck go fast.......
Check the main coil plug for the left bank.
Old Jun 27, 2011 | 10:58 PM
static06's Avatar
ahh thanks for correcting me. it makes sense now why it didnt change the idle. ill check the main coil plug tomorrow after school when i get home
bearden86
26
Nov 15, 2015 03:58 PM
Tydriver
45
Oct 23, 2015 09:19 PM
Velocity1
Sep 22, 2015 01:32 PM
creekrat
Sep 10, 2015 12:59 AM
CammedZ71
11
Sep 9, 2015 02:05 PM
