P0155 and P0135
Old Nov 18, 2011 | 12:49 AM
  #21
mcfarlnd's Avatar
Un-Registered User
Let me know if you need some help. Shoot me a PM and I can look up the wiring schematic to let you know what pins in the PCMs you need to go from to the sensor. You can probably rent a meter from auto zone or orielly's.
Old Nov 18, 2011 | 03:05 PM
  #22
Slammed96's Avatar
Checked continuity and everything was good, also got ahold of a Tech II scanner and did a little playing. Found a 0 volt output, and resulting 0 volt input from the computer, leading me to believe that that is where the problem is coming from. I left a message with Nelson Performance, so hopefully it can get straightened out here in the near future.
Old Nov 19, 2011 | 12:11 AM
  #23
mcfarlnd's Avatar
Un-Registered User
Sweet. Glad you are getting it Figured out. Keep us updated. Very curious as to where the problem is?
Old Nov 19, 2011 | 10:44 AM
  #24
Slammed96's Avatar
As am I. I'm just hoping it won't hurt the truck any driving it an hour back home for the holiday break. Hopefully Monday Nelson gets back to me and sends out a new ecm.
Old Nov 19, 2011 | 10:50 PM
  #25
63chevy's Avatar
i've seen a lot of problems with o2 sensor harnesses rubbing on the front driveshaft might be worth looking into
Old Nov 20, 2011 | 12:44 PM
  #26
Slammed96's Avatar
Thanks for the tip. Mines a 2wd though, so I can rule that out. I'll keep it in mind for any of my 4x4 friends who may encounter the problem.
Old Nov 20, 2011 | 11:09 PM
  #27
63chevy's Avatar
that makes sense lol
Old Nov 22, 2011 | 01:24 PM
  #28
Slammed96's Avatar
Just an update, was out today doing a few more checks and jiggling wires, cleared the codes out and so far they have not come back, so who knows, I may have inadvertently fixed something. Hopefully I did, but just wanted to say big thanks for everyone who helped me with this.
Old Nov 28, 2011 | 12:30 PM
  #29
Slammed96's Avatar
Well, went out and fired up the truck the other day and the light came back on. Same heater codes as before (PO135, PO155) so the problem is still there. Think my next step will be to return these o2's and get a set of GM sensors. Otherwise I'm lost as to were the problem is.
Old Nov 28, 2011 | 12:47 PM
  #30
1FastBrick's Avatar
Custm2500's Rude Friend
Did you get your replacment PCM yet??? You mentioned 0 input and 0 output
