P0118 engine coolant temp sensor high voltage?
Old Feb 24, 2014 | 01:20 PM
way2much_01's Avatar
Default P0118 engine coolant temp sensor high voltage?
Hello guys I had this code pop up on me about 8-9 months ago and I changed out my crank position sensor and it went away and now it's back and I have no clue where it's coming from. I changed out the crank sensor again and the ect sensor and the code is still popping up there hasn't been anything done electrical wise to the truck in 2 years. I did some searching as it my be an open circuit but what exactly dose that mean (short, bad ground)? any help is appreciated this thing is driving me bananas...thanks
Old Feb 24, 2014 | 01:32 PM
Ferocity02's Avatar
If it's a ECT code why are you changing the crank position sensor?
Old Feb 24, 2014 | 03:10 PM
Because when I did the engine swap I used the old sensors so when I got this code 8 months ago I decided to change out the sensors I didn't replace so when I changed out the crank position sensor the code went away so that's why I changed it out again but this time the code is still there
ullose272
Aug 5, 2016 02:05 PM
BIGD4504
Jul 28, 2015 11:46 AM
ullose272
11
Jul 17, 2015 07:22 AM
Bluecollar Hotrods
Jul 16, 2015 08:52 PM
jrplz
Jul 9, 2015 12:07 AM
