An OS without EVAP monitoring?
I looked at some of the Holden stuff and EVAP is active on them as well.
Nope. Don't disable EVAP. Simply set all the EVAP codes to not set. This will cause the EVAP system to get stuck in a perpetual "Incomplete" state. It won't ever complete, but at least it will look like it's trying.
Most state inspections will allow at least one incomplete system to pass. If your state requires 0 incomplete to pass, you're probably still going to have to get a not-equipped OS.
0 - MIL on First Error
1 - MIL on Second Error
2 - NO MIL Light
3 - NO Error Reported
You are required to show up with a COMPLETED status, typically by performing a "drive cycle". Then they Clear codes and want to see Incomplete. I guess what your saying is set to 2, so no MIL, but would give a "pending" status. But this won't satisfy the COMPLETED status you need initially.
I'm not even sure where this DMV procedure comes from. I think the guys at the inspection station came up with it themselves. Without investigating I doubt its in writing anywhere, but how do you argue?
Yeah, there procedure is new, like in the past 3 months or so.
To make sure I am understanding you right. They clear the codes and want the system to not pass the readiness tests, then make it pass the readiness tests? If that is what you mean, it would be extremely time consuming, and I am sure an inspection would cost well over $100 or nobody would do them. If that is what they are doing, I would suggest to find an inspection station you can be friends with, and flash in 2 tunes. One tune that will pass the readiness tests, and one that will fail. He will be happy to find that info from you since all inspection station mechanics are gear heads too. They would have vehicles, and friends with vehicles that need to pass too.
Also this isn't a regular Inspection station. This is a State Referee that is employed by the state to enforce the smog laws. This person can make or break your engine swap when swapping it into an older vehicle.
The problem is the Laws can be Vague and its up to the Referee to use his judgment on whether to pass it or not.
If you can't find an OS that has that stuff removed, My advice would be to find another referee or find an area that does not require a smog check and register it there.
I noticed GM no longer sells the LS1 engine swap kit and most of there stuff is now labeled as legal for swap into a pre 1976 and older vehicle's.
Believe me its the most crazy thing SMOG related I've seen in a long time. And in Nevada of all places. You'd expect it maybe from California but I've been pulling my hair to find a work-around for this.
What they're doing is trying to make sure you didn't just clear a check engine light and come in for an inspection.
Unfortunately in Nevada everything is done via County, and there is only 1 inspection station in Washoe County for Reno, NV. They have also cracked down on validating registration addresses too. You can no longer use a PO Box on your registration.
