OEM E-Fans + Nelson Harness not working
Old Dec 23, 2011 | 03:57 PM
nonnieselman's Avatar
Ive been using optitronic 30A relays from advanced auto for about 6? Years now. Never had a issue. They were only $4 too.
Im not sure how they set the tunes. But i have mine when the fans do come on they stay on for as lang as possible after the target ECT is met. That way the relay isnt constantly gettin switched.
Also ran 10ga hi-temp wire and grounded really good.
If yall need some help making a harness lemme know.
Old Dec 25, 2011 | 08:19 PM
02'Z71ONDUBZ''s Avatar
if their both never coming on then they forgot to turn on the settings for the pcm pin, or your ect is never reaching the trigger point they set in the tune. You have an aftermarket stat? I know I tapped the right green wire, mine come on like they are supposed to when the compressor clutch engages. I am using borg warner relays. I noticed the plastic around the relay for the pcm pin is melted a little where it plugs in, and the relays that blow sometimes have white around the terminal like they got hot. I'm probably going to start by increasing the size of the ground wires for the harness, but really have no idea if that will solve the problem.
Old Dec 25, 2011 | 08:58 PM
MikeGyver's Avatar
You're burning relays at the coil terminals (86 or 85)? That's seriously wrong. That sounds like some kind of back feed problem that needs a diode to resolve.
Old Dec 25, 2011 | 11:28 PM
sikhd's Avatar
Had the same harness for a while and never had a problem. Like the other guys said check out the relays.
Old Dec 26, 2011 | 01:26 AM
the only thing wrong with the relays is that their blowing... I know something is wrong. Everything is hooked up correct though, power is coming from the red distribution block and the ground is hooked up to the alternator bracket I believe, however nelson recommends to hook it up. The relay thats giving the most trouble is the one on the end closest to the fans, seems to control the ect pin 42. Expound on a diode and why I would need it?
Old Dec 26, 2011 | 05:13 PM
MikeGyver's Avatar
If indeed your burning relays are caused by a back feed through a coil terminal, a diode in that terminal's wire will keep the electricity from flowing in the wrong direction.
pupi305
Aug 13, 2015 03:48 PM
Ammadien
Jul 22, 2015 08:50 PM
01sierraon22s
Jul 8, 2015 11:26 AM
GreyChevy
Jul 7, 2015 08:57 PM
