No Power
Old Sep 16, 2009 | 03:56 PM
Default No Power
My truck was parked a little over a year ago and has sat since. I recently wanted to get it going again but it will not start (no fuel pressure). I replaced the fuel pump but come to find out there is no power to the pump. I have checked for any popped fuses and everything seems fine and the wiring from the tank to the underhood fuse block is fine as well.
Any sugestions?
Old Sep 16, 2009 | 03:57 PM
GMCtrk's Avatar
dead battery? lol
Old Sep 16, 2009 | 04:01 PM
The truck cranks over and everything else works except for the fuel pump.
Old Sep 16, 2009 | 04:03 PM
GMCtrk's Avatar
animals may have chewed the wires up. Also the pump wires have been known to melt.
Old Sep 16, 2009 | 04:14 PM
dirt track racer 81's Avatar
get a volt meter and check the wires to the fuel pump. they should get voltage right as you turn the key on, then after a few seconds it will go off if the motor is not cranking. if you do have voltage check the connection. if not go back to your fuse box and check your relay, if ya cant figure it out could just poor boy it and hard wire it in with a key on thru a relay
andrewlong
Nov 9, 2016 09:38 AM
Superman09
Sep 25, 2015 05:55 AM
Brandonlflr12
Sep 9, 2015 03:54 PM
andrewlong
Sep 8, 2015 10:25 PM
