2008 5.3 using 99-02 harness
ok maybe someone who actually knows(i have no clue!)
i have a 2008 5.3L with 799 heads. im doing a DBC 90mm TB with a nelson harness. they make their harnesses for the 99-02 engines which uses a knock sensor valley cover. im using an 02 ECM on this also. the tranny is an 06 4L60E.
now heres my question. do i have to change the valley cover to the older style then change lifters so it isnt using the DOD lifters anymore since im using an older ECM and harness? can i just leave it how it is and tune the knock sensors out? the motor doesnt have them anyways so i should be ok without adding them right? please help, ive sunk a lot of money into this swap and id never get it back. so to keep from spending money on parts that i dont need, please help.
my 94
my 08 is on a stand still till this is done, then KBracing, here i come!
i just found out the 08 GenIV has knock sensors on the outside of the block. if i was to just get the Nelson harness knock sensor wires longer so they reach my knock sensors then plug them up like normal. ill be able to leave the valley cover and lifters alone right?
i have the injector pig tails and some other pig tails for the sensors on the motor that i could probably send to Nelson and have them wire them up the right way vs me splicing my pig tails in.
TimDave217
Aug 24, 2015 04:38 PM
oharajo
Jul 18, 2015 09:24 PM
grantpo
Jul 15, 2015 12:21 PM
