No PE mode. Causes?
Old 04-23-2013, 01:51 PM
Ender06's Avatar
Default No PE mode. Causes?
2002 8.1L
N/A 60lb injectors
EFI Live tuned,
150,000 miles
OK guys. I've noticed for a while that the truck doesn't do well at full throttle. Just figured it was age, but I borrowed a Wideband and found out the truck will not enter POWER ENRICHMENT. Thought for sure it was just my lack of tuning abilities but I flashed the stock tune back in and just adjusted Injector Flow Rate for the 60#'s. STILL no PE mode. What could be causing this? O2 sensors? MAF?
Our truck pull season starts this weekend and I would really like to find out before it starts. Thanks guys.
Old 04-23-2013, 02:22 PM
Area47's Avatar
whats the delay timer set to?
whats the trigger tps set to?
is the kpa trigger still used?
Old 04-23-2013, 02:24 PM
silverado6.2's Avatar
Totally different truck/engine combo but I have a 1998 454 truck and the stock tune has a 60 second delay for pe making it non-existent. Mine is now set to 0.
Ender06's Avatar
Can't tell you right off hand, computer is at home, but all of that has been left at stock values.
Old 04-23-2013, 02:25 PM
Ender06's Avatar
Definitely something I will look at as soon as I get home! Possibly GM's attempt to save fuel in the big blocks? Who knows....
Old 04-23-2013, 02:26 PM
nonnieselman's Avatar
Yep.. stock tune is setup for a 60 second pe delay..
It makes quite a big difference once you dial in the AFR and get some timing in it down low.
Old 04-23-2013, 02:27 PM
Ender06's Avatar
Area47, if I remember correctly I think the TPS trigger was around 60%. Not sure tho.
with the 454 it was the only way gm could get it to pass smog. I'm sure there was a warranty benefit for them too, same with torque management.
Old 04-23-2013, 02:30 PM
Ender06's Avatar
Serious????? I feel like its getting dangerously lean in hard WOT pulls, and all for that reason....geez
Old 04-23-2013, 02:31 PM
Serious????? I feel like its getting g dangerously lean in hard WOT pulls, and all for that reason....geez
They counteract the meltdown threat by pulling more timing out
Quick Reply: No PE mode. Causes?
