no going in PE soon enough??
Hi everyone the truck is a 08 chevy , a 427, 60 lbs injectors, procharger, long tubes (?? model).
when I mash the throttle bellow 2500 rpm ti puff( goes really lean) , it doenst hapend if you move the throotle slowly
then... when your floor it it has some delay to go in PE
I tried activating ve when yo look at the throttle, going rally high on new ve and then on MAf...it doesnt work... or maibe I dindnt try it the right way.
here are 2 logs and my tune file.... it odne in beta because de 4l80 swap
I really apreciatte any pointer
Did you change your enrichment rate? Lower is less delay I believe....
You might post up your tune file and we can give you some pointers. I'll have to wait till I get home from work to look at it...
Hello Dave
