Nnbs alternator on nbs
Old Aug 9, 2017 | 12:00 AM
Grzmny's Avatar
Default Nnbs alternator on nbs
I have an alternator from a 2010 5.3 ( which I believe is a 145amp) and I want to use it on my 2000 5.3. The difference I noticed is the wiring. My current 2000 alternator has a 4 pin plug with only one wire being used. The 2010 alternator has a 2 wire plug. If I'm able to use this alternator how do I wire it? Or should I keep my 105a and install a overdrive pulley. I did efan swap and noticed voltage drop at idle. Thanks!
Old Aug 9, 2017 | 12:08 AM
Atomic's Avatar
I have a gauge for that
I did this exact thing and just replaced the regulator on the alternator with the proper one. Not too hard, only costs about $40 IIRC.
Old Aug 9, 2017 | 12:21 AM
Atomic's Avatar
Pretty sure this is the one I used. http://store.alternatorparts.com/d3579--.aspx
Old Aug 9, 2017 | 03:45 AM
Grzmny's Avatar
Mine is a 2000 truck. I don't have a dr44 factory. I read more into it last night and a overdrive pulley might be simpler
Old Aug 9, 2017 | 06:10 AM
ezdaar's Avatar
Overdrive pulley just overspins the alt.
Puts into charge mode sooner, it does not increase its amp output rating.
Its a bandaid, buy a better alt.
Old Aug 9, 2017 | 07:09 AM
Grzmny's Avatar
Not a problem. I understand a pulley swap would be a bandaid. What would be the most budget friendly higher output alternator?
Old Aug 9, 2017 | 08:14 AM
Atomic's Avatar
My truck is a 99... it came with the same alternator you have and the alt I put in there by changing the regulator was from an 07 or 08 truck.
