Nnbs alternator on nbs
I have an alternator from a 2010 5.3 ( which I believe is a 145amp) and I want to use it on my 2000 5.3. The difference I noticed is the wiring. My current 2000 alternator has a 4 pin plug with only one wire being used. The 2010 alternator has a 2 wire plug. If I'm able to use this alternator how do I wire it? Or should I keep my 105a and install a overdrive pulley. I did efan swap and noticed voltage drop at idle. Thanks!
Not a problem. I understand a pulley swap would be a bandaid. What would be the most budget friendly higher output alternator?
