NEW PRODUCT: 2007 Silverado/Sierra Predator Programmer
Diablosport has released their Predator programmer for the 2007 4.8, 5.3 and 6.0 Silverado and Sierra! The part number is U7192 and our price is $399.99. This includes free overnight shipping in the 48 states.
U7192 Stock Vehicle Tunes:
Performance Tune: Designed to add power and torque using premium fuel.
87 Octane Tune: (Trucks Only) Designed to add power and torque using low to mid grade fuel.
Factory Tune: Designed for users who wants to adjust parameters using the factory tune.
U7192 Specific Features:
Timing Table 2000-4000rpm (+15/- 20%)
Timing Table 4000-7000rpm (+15/- 20%)
Fuel Table 2000-4000rpm (+/- 20%)
Fuel Table 4000-7000rpm (+/- 20%)
Idle (+ 500rpm / -300rpm)
Speed Limiters (Trucks Only)
Rev Limiters
RPM Shift Points
MPH Up and Downshifts
Shift Timing
Shift Pressure
Cooling Fan ON and OFF temperatures
Re-Calibrate Speedometer for Gear and Tire Size Changes
Torque Management abuse mode time limit ON/OFF
% torque reduction vs. RPM ON/OFF
Upshift torque reduction (all gears) ON/OFF
Adjust for different injector size
Adjust for long term fuel trims
Disable P0430 and P0430 codes
Adjust COT enable temperature
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
Enable/disable MPH, set high to disable
Disable P-codes: 0400,0401,0402, 0405, 1404 and 1409
Disable P-codes: 0410, 0412 and 0418
Disable P-codes: 0137, 0138, 0140, 0141, 0157, 0158, 0160 and 0161
All standard DiabloSport Predator features
*Transmission functions do not apply to trucks with the Allison transmission.
Tuning for other 2007 GM Trucks will be available in the future.
Rev Limiters
RPM Shift Points
Shift Timing
Shift Pressure
Misfire Low rev
Misfire Low cyl
Misfire idle cyl
calsdad
Jun 14, 2023 11:07 PM
