Need some help with a tune
Old Jun 21, 2011 | 02:19 PM
00ChevyScott's Avatar
Wearin' da big hat
Default Need some help with a tune
A friend of Royces is having major issues with his truck. It's a 99 Silverado with a 6.0, MS3 cam, 8.1 truck injectors, and bolt ons. It has an aftermarket converter as well. I don't have a decent PID list as I am using a new laptop, so I used the default LS2 PIDs. If any of you wouldn't mind taking a look at the tune/log, I'm sure he'd appreciate it.
Truck is running rich, seems to be missfiring, has trouble idling both in park and in drive after letting off throttle. At idle it might be showing excessive knock in the log due to a worn motor mount letting the longtube contact the frame.
File Type: tun
File Type: efi
Old Jun 21, 2011 | 04:10 PM
Wearin' da big hat
bumpity
Old Jun 21, 2011 | 04:29 PM
KLUG'S SS's Avatar
FormerVendor
Originally Posted by 00ChevyScott
bumpity
Hey man, I'd be happy to take a look at what you got going on there when I get to an actual computer a little later this evening. Can't see much from the ole I Phone right now. Lol.
Old Jun 21, 2011 | 04:48 PM
Wearin' da big hat
Thanks!
Old Jun 21, 2011 | 09:31 PM
KLUG'S SS's Avatar
FormerVendor
Has the RAF tuning been done to get the idle airflow in line with what the engine is wanting? Also injector data is off for those injectors, I see the injector flow rate table has been changed but the voltage offsets, short pulse adder, min. pulsewidth are still the stock values for the injectors that came stock in that truck, injector flow rate even looks a tad high for those 8.1 truck injectors. Those 8.1's flow right at about 30 lbs, I believe if my memory serves me right in a stock tune file for a truck with the 8.1 the IFR should be at something like 29.9. I'd find and pull up a stock tune file for any stock 8.1 truck tune file and get all of the right injector data copied over in that tune for starters.
I would also add maybe a couple hundred more rpms to the idle tables as well, that MS3 is actually a pretty healthy cam and the desired idle speed tables in that tune are actually pretty close and just slightly larger to what I have mine set at in my truck with my smaller 224/230 cam. After getting all of the correct injector data in the tune I would revisit the VE table. Then do your RAF tuning, krambo's got a very nice detailed write up on this as a sticky here in the tuning section!
After you get the idle airflow right and whatnot you could probably even drop the idle rpms back down some if the guy wants plenty of lope at idle but until then like I said I would definately add 200 more rpm or so so you don't have the truck fighting you and wanting to die while you are trying to get the other bugs worked out.
Old Jun 22, 2011 | 03:45 PM
Wearin' da big hat
Thank you for taking the time to look through it! Guess he's going to have to pay someone that actually knows what they're doing to tune it.
Old Jun 22, 2011 | 09:01 PM
BlackGMC's Avatar
Resident Retard
dude, i bet his truck runs like crap.... that log is horrible....
Old Jun 23, 2011 | 03:22 PM
RSTinOKC's Avatar
Absolute curiosity here because I am ignorant to EFILive, but does its scanner function not come with pre-configured PID's?
Old Jun 23, 2011 | 03:57 PM
Wearin' da big hat
It does, but they're very general and basic. There are better PIDs to log that show more important information.
Old Jun 23, 2011 | 07:38 PM
Rhino79's Avatar
9 Second Club
You get it lined out or still need some help?
