need some help quick.. ignition switch?????
Old Nov 28, 2011 | 06:11 PM
726.0chevelle's Avatar
13 Second Truck Club
Default need some help quick.. ignition switch?????
I have a 99 ecsb silverado and lately when i try to start the truck nothing happens. But if I try to turn the key 5 minutes later it will fire right up. I checked all of the conections on the battery and starter and they all look perfect. Today I tried to crank it and its like the battery is completely dead but is does the same thing when I have jumper cables hooked to it. When the door is open the dome light is on bright but when i turn the key everything shuts off. Does this sound like the ignition switch. And if it is is there any computer tuning of any sorts with the VATS when it is changed. Thanks for any help
Old Nov 29, 2011 | 05:53 PM
budhayes3's Avatar
PT's Slowest Truck
Check to see if you have 12v getting to the starter solenoid while someone turns the key. If so, the starter is at fault, if not, the ignition switch or it's circuit may be suspect
OHsixLS3
Nov 21, 2015 10:41 AM
dsbodley
Nov 14, 2015 09:46 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
