Need A lil help here
Old Dec 18, 2009 | 12:30 AM
Default Need A lil help here
So my truck is throwing a p1345 code I have no clue on where to start.. I did some research on that code but i dont quite understand the meaning. Help is greatly appreciated thanks in advance for any input into this guys.
Old Dec 18, 2009 | 12:33 AM
Dewey's Avatar
any more info? miles, mods, misfires?
the best i can gather is that either one of your position sensors need to be replaced, or your timing chain is doing something it's not supposed to.
Old Dec 18, 2009 | 12:47 AM
Miles are 80XXX no mods, no misfires the only thing i notice is sometimes when im going to start it up it turns and then starts. can you tell me where those (if more than 1) sensors are located?
Old Dec 18, 2009 | 12:55 AM
Dewey's Avatar
i'm pretty sure the cam position sensor is at the top of the block right under the back of the intake mani. that one should be replaceable with the motor in the truck. the crank position sensor is near the back of the engine block, on the passenger side, near the starter. you have to pull the motor to replace that one IIRC.
Old Dec 18, 2009 | 01:11 AM
cool thanks man ill look into that, the previous owner said he sent the truck out to get the intake manifold's gaskets replaced because of somesort of leak. He said unless the mechanic forgot to plug something in thats all the info i have from him.
Old Dec 18, 2009 | 08:12 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
you had this posted in the western section......you'll get a better response here
Old Dec 18, 2009 | 01:02 PM
Yeah i did. Im doing more research on that code it seems that its common on allot of chevys. But any input i get would be awesome, thanks fellas.
Old Dec 18, 2009 | 01:05 PM
00ChevyScott's Avatar
Wearin' da big hat
What kind of truck is it? I searched it on google and kept getting 98 and older trucks that had problems with the distributors.
Old Dec 20, 2009 | 03:37 AM
IT is a 99 chevy tahoe limited i checked the cap and rotor and it showed allot of wear so i replaced that and the cam sensor, cleared the code and same thing in a matter of seconds it comes back on.... So i might check the timing maybe? or and changing the crank sensor
Old Dec 20, 2009 | 09:34 AM
Truckshop's Avatar
itsa vortec motor. its out of time. have the timing set and the light will stay off. very common after intake gasket replacement. you need a scanner to synchronize the cam and crank sensors. crank sensor is in the timing cover and the cam sensor is the pick-up in the distributor. nothing is wrong with the sensors its just not timed correctly.
