need info for a 5.3 4l80e tune
hey guys
my buiddy just did a 4l80e swap into his 2000 silverado with a 5.3L in it. He called me up to tune it but i dont know what i have to change to make the 4l80e work with the 5.3, do i need to do a custom OS? i have a tune from a 2002 6.0L 4l80e 2500 silverado
or if anyone has a file i can just load in so i can get it running id apreciate it
thanks
Andrew
thanks
Andrew
i just realized i forgot to say im using HP tuners
when i get home ill grab the OS #s and post them up
will i have to just write a 4l80e-6.0 tune to the PCM then change the engine tables?
ill post up the OS# when i get home in an hour- thanks
ok so i talked to one of my friends and he said i can take a stock bin from a HD truck with a 6.0 and 4l80e and change all the engine tables over to my 5.3 tables and it should work
only problem is it seems the only tune i have here or in the repository is a 2001 silverado 6.0 with a 4l80e and it has drive by wire were as the one im working on is cable operated
the truck that im tuneings operating system is 9381344, the closest tune i found is 12208322
can anyone help me out?
yep i searched 6.0L engine in all years makes and models- i cant find any cable operated throttle body tunes
if somone out there has a 4l80e tune for a 2000 GM truck with a cable throttlebody that would be awsome
hmmm a guy on here that i talk to told me he has done it befor, i found a tune for a 2000 HD and swapped all of my engine tables over, the tune looks good, im gonna try it out tomorrow
the one i have is for the same year, same operating system as what im working on, it was just a 6.0 with a 4l80e instead of a 5.3 with a 4l80e
ill flash it and see if it works
