need help with shift points
Old Dec 6, 2011 | 05:01 PM
getonit's Avatar
Default need help with shift points
I changed my gears from 3.42 to a 4.10 with 295/50/16-27.7 tall tires. My rpms on 1/2 is 6350 and 2/3 is 6300 and 3/4 is 5800 in tow haul. In normal it is 6000 in 1/2 and 2/3 and 5800 at 3/4. I used a speed calculater that blackgmc posted on here but it still don't shift right. I adjusted the rpm and shift speed. Am I missing something. Its still shifting crazy. Im using hptuners.
Old Dec 6, 2011 | 05:03 PM
getonit's Avatar
I also went from a 3000 stall to a 4000. Do I make any adjustments for that or is it about the same?
Old Dec 6, 2011 | 05:09 PM
Rhino79's Avatar
9 Second Club
The looser the verter, the lower the mph will haveto be. Set the rpm where you want it. Then drop the wot mph by 1-2 mph at a time. Also make sure the part throttle table at 100% throttle match. Make sure wot and part throtle downshift tables are lower than the upshift.
Old Dec 6, 2011 | 05:13 PM
getonit's Avatar
Do I need to adjust the tps/rpm/speed tables??
Old Dec 6, 2011 | 06:02 PM
Rhino79's Avatar
9 Second Club
Yes. I don't have my pc w me, but in efilive there are tables for part throttle based off tps, and wot vs mph and wot vs rpm.
Old Dec 6, 2011 | 06:15 PM
andrew383's Avatar
traveling mod
I would start with zeroing out the WOT mph and just set your RPM and relog to see what its shifting at mph wise,then adjust from there..
MikeD.
Oct 13, 2015 08:08 AM
jtphelps289
Sep 29, 2015 12:00 PM
Lthompson
Sep 15, 2015 07:55 PM
TAPyvehc93
Sep 14, 2015 01:22 PM
xerox17
Sep 5, 2015 01:23 PM
