NEED HELP!!! Quick come in!
Old Jul 31, 2010 | 05:24 PM
Fastcount03's Avatar
Default NEED HELP!!! Quick come in!
I have a 2000 ECSB GMC with a 4.8/4L60E. It supposedly has a 3200 stall and a comp 220 cam. I don't know either to be true. It stumbles off idle and runs like crap, I have had it tuned, but he says that with the code there is a mechanical problem somewhere and it has to be fixed to proceed. It keeps throwing a P0121 code and I have replaced the TPS, the map, and intake gaskets. I have sprayed it down several times trying to find a vacuum leak with no luck. The brakes are also very weak, with a hard peddle. Has anyone had this problem or know what it could possibly be? Thanks in advance.
Old Jul 31, 2010 | 05:42 PM
knuckles's Avatar
is the brake boost hose on right? or your brake booster is done for.
Old Jul 31, 2010 | 05:46 PM
Suddog's Avatar
Originally Posted by knuckles
is the brake boost hose on right? Or your brake booster is done for.
^^^^x2^^^^^
Old Jul 31, 2010 | 06:05 PM
That's what i was thinking, but I can unplug it and the truck still surges on idle? I am thinking that this is all one big problem, but I just don't know what it is. Kinda just guessing from here, I don't wanna dish out $100+ unless I'm sure it's gonna fix my problem.
Old Aug 1, 2010 | 04:48 PM
Ok, so I don't think that the brake booster is my problem. After doing a little more research and asking around, maybe it could be that the cam in the truck was installed incorrectly and I need to tear into the motor. Somebody please stop me from making a big mistake or wasting time if you know what this could be. The motor doesn't run like it should, but I have fixed the code.
Old Aug 2, 2010 | 06:25 AM
03_Denali's Avatar
"Somebody please stop me from making a big mistake or wasting time if you know what this could be. The motor doesn't run like it should"
Not trying to sound like a dick, but it only takes an hour, start to finish, checking the timing references for the cam. It's a process of troubleshooting; you could have had it torn apart in the time you have read this...lol Always do the free stuff first!
Old Aug 2, 2010 | 09:43 AM
00ChevyScott's Avatar
Wearin' da big hat
Maybe an hour of you have all the right tools already and know exactly what to do. If you've never done it before, I could see it taking much longer.
Old Aug 2, 2010 | 10:06 AM
Coban's Avatar
When you unplugged it from the brake booster, did you plug the line so it wouldn't be a huge vacuum leak?
Old Aug 2, 2010 | 10:49 AM
Well if I knew how and what to look for, maybe your right. Can you please explain the procedure so I don't waste anymore time and money. Thanks.
Old Aug 2, 2010 | 10:50 AM
Yes, I held my hand over the line and it still surged.
