Need help on Clutch safety switch "UPGRADE"
Old Jul 3, 2016 | 11:15 PM
DrX's Avatar
DrX
Brown(solid) and Purple should also be a pair. Normally open I believe.
Old Jul 6, 2016 | 05:24 AM
SLOPONY's Avatar
I hooked the factory switch to a circuit tester that ran all circuits at once and purple and brown never closed a circuit together. They may work together down stream or at the bcm, but not inside the switch.
Old Jul 7, 2016 | 02:29 PM
DrX's Avatar
DrX
Looks like 441 actually feeds 420 via the brake switch(normally closed).
Old Jul 8, 2016 | 11:06 AM
SLOPONY's Avatar
I wired the micro switches up so they work in the same manor as the factory switch, so if that circuit connects later down stream, then it should still be functioning as normal.
Old Jul 9, 2016 | 07:46 AM
SLOPONY's Avatar
After looking again, it's the same circuit as the brake pedal for the cruise interrupt.
Old Jan 4, 2017 | 04:41 PM
2002_Z28_Six_Speed's Avatar
Just as an update over here my motor blew up so I am having the motor rebuilt. I also sourced a nv4500 for the truck since my 60E had 210K miles on it. It was already out of the truck anyways. If I can confirm any info I will post it up.
Old Jan 12, 2017 | 05:11 AM
SLOPONY's Avatar
I ended up solving the issue, and like most people, I never updated the post with what the solution was.
I installed 3 micro switches, and wired them the same as the three legs of the factory clutch safety switch. The issue I was having that was making me scratch my head, was that it did not allow the truck to crank, and it turned out to be the green connector that plugs in to the junction box at the bottom of the firewall near the floor. It was loose, and not clicked in. I plugged that in, and POOF all worked awesome. I drove the truck all summer, and not one issue with it!
Old Jan 13, 2017 | 05:04 PM
Did you ever get your cruise control fixed? I am thinking the truck wont crank unless it think it is in P N and cruise control probably wont work unless the truck thinks it is in gear.
Old Jan 15, 2017 | 05:53 AM
SLOPONY's Avatar
My truck is a stripper model, No cruise. But if it did have it, it would work.
Old Jan 15, 2017 | 05:58 AM
SLOPONY's Avatar
Dusty05
Jul 12, 2016 04:19 PM
Tehcaptainjack
11
Jun 2, 2016 06:47 PM
nathanstowing
Jun 1, 2016 06:04 PM
