Need help, cant rev past 2500
Old Dec 26, 2008 | 06:05 PM
MOTTRHED's Avatar
MASS seller approved
Default Need help, cant rev past 2500
Ok Im going out of my mind with this thing. My trans was slipping and the stock 5.3 wouldnt rev past 2500 and bogged and bucked, so I said screw it and bought a 6.0 and 4l80e... And still the same problem with not being able to rev... so heres the specs.
00 RCSB 4X4
00 lq4
799 heads
TR valvesprings
TR 224 cam
TR pushrods
02 4l80e stock(4x4)
Ls1 fans-nelson harness
CAI
Pacesetter LT
Dual 3 inch ex out in front of pass tire
Dual 3 in high flow cats
Nelson tune
So after all that still the same crap going on...
So here is what Ive replaced in search of the answer
New wires
New plugs
New fuel filter
New front O2s(rear deleted)
Pretty much everything else was changed in the swap
I stole a maf from my friends truck... no difference
So that leaves the wire harness and the fuel pump as the only 2 things that havent been changed. And the fuel pump was done less the a year ago...
Im drawing a blank, anyone see anything I may have overlooked?
Old Dec 26, 2008 | 06:11 PM
BlackGMC's Avatar
Resident Retard
I would check your fuel pressure, sounds like you pump may not be putting out enough...
Old Dec 26, 2008 | 06:17 PM
MOTTRHED's Avatar
That is the game plan for tomorrow, does anyone know the spec... I would assume around 60psi
Old Dec 26, 2008 | 06:36 PM
Mangled03gmc's Avatar
Baltimore Whore
Yep about that..
John
Old Dec 28, 2008 | 08:48 AM
MOTTRHED's Avatar
Ok well I checked pressure and at idle it was about 40psi and if you let it sit there and idle it slowly dropped. If you rev it it would drop to 0. So I changed the pump and it runs perfect, thanks guys.
Old Dec 28, 2008 | 09:13 AM
BlownChevy's Avatar
blownerator
25 Year Member
Make sure you replace the filter and the fuel pressure regulator as well. Damn, sounds like that fuel pump cost you about 2500 bucks! Congrats on getting it figured out.
Old Dec 28, 2008 | 05:07 PM
MOTTRHED's Avatar
More like 7000, but alot of things were replaced and it was a good excuse to do what I always wanted.
calsdad
Jun 14, 2023 11:07 PM
Blwn99x
Mar 24, 2023 11:14 AM
Vortec350ss
Jan 12, 2016 10:36 PM
bearden86
26
Nov 15, 2015 03:58 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
