Need help 4 transmissions lost 3rd and fourth must be electric
Old Jun 24, 2016 | 11:53 AM
  #21
the68cam's Avatar
Registered User
Today I started truck and took off and transmission works perfectly for about ten miles then it felt like it hit neutral and slipping 3rd and fourth so I stopped and turned it off then restarted it and took off again and it worked perfectly again . This is driving me crazy !! What would cause this ?
Old Jun 24, 2016 | 12:02 PM
  #22
Wolftrk99's Avatar
Something sticking when it gets hot and expands...with oressure behind it then when you shut it off the pressure drops.... 3rd accumulator check valve and 3-4 accumulator, would be first two things to check, the 3/4 accumulator could be worn causing it to **** in the bore.... Coukd also be a stuck valve in the valve body...
Old Jun 24, 2016 | 12:06 PM
  #23
the68cam's Avatar
Registered User
You don't think it's the ignition switch or something else electronic ? Doesn't matter if transmission is warm or cold
Old Jun 24, 2016 | 12:13 PM
  #24
Wolftrk99's Avatar
As constant of an issue as this is, no its something in the trans.... Could even be something going on with the input drum which houses the 3-4 clutch pack
Old Jun 24, 2016 | 03:10 PM
  #25
the68cam's Avatar
Registered User
Okay went to drive it again and soon as I put it in reverse and wouldn't go nowhere I give it a little gas then jerked into reverse took off and drove fine a little while then lost 3rd and fourth again
Old Jun 24, 2016 | 03:40 PM
  #26
Wolftrk99's Avatar
You have an intenal issue.... Take it back to whoever built the trabs and tell them when its fixed you will come get it, at this point it sounds like they arebt even test driving the damn thing after going through it....
Old Jun 24, 2016 | 03:50 PM
  #27
the68cam's Avatar
Registered User
It worked fine for 2000 miles
Old Jun 24, 2016 | 03:55 PM
  #28
Wolftrk99's Avatar
Ok, would still take it back, how long has it been? 2000 miles isnt anywhere near ling enough on a rebuild!!!
Old Jun 24, 2016 | 03:57 PM
  #29
the68cam's Avatar
Registered User
The last three times maybe two months it works perfectly then bam no third and fourth gear
Old Jun 24, 2016 | 04:34 PM
  #30
Wolftrk99's Avatar
Either get them to fix it for good or find another builder
