Name this part
Old Jul 29, 2016 | 02:21 AM
BlueTexan24's Avatar
Default Name this part
What is this little red box called that is inline with the battery and alternator? I can't find it anywhere and mines obviously a little corroded. It actually caused the wire coming from the alternator to the red box to corrode so much it broke, and I also had my fuel pump hot wired onto the post on the back of the alternator so the truck died when it happened in my driveway. Also my efans are wired inside that box, but the wires still look okay on that harness at least. I didn't realize why the pump had no power since I never actually opened the damn thing up to look inside
Old Jul 29, 2016 | 08:23 AM
TXsilverado's Avatar
Id grab one from your local junkyard. Looks more like heat than corrosion to me.
Old Jul 29, 2016 | 10:51 AM
About20ninj45's Avatar
I agree. Whatever you had in there was coming off the backside of the fused link and got to hot.
Old Jul 29, 2016 | 11:48 AM
2002_Z28_Six_Speed's Avatar
Corrosion can increase the resistance and cause excessive heat. In this case someone probably used an undersized wire and the excessive heat killed the plastic.
Old Jul 29, 2016 | 02:58 PM
the starter got stuck on for probably 30 seconds before I could disconect the battery back when I did the 80e swap and I bet it got that box super hot and melted it then and it's just gotten worse over time. Truck is 17 years old this year, so I'm sure some moisture has made its way in there as well.
Old Jul 29, 2016 | 11:05 PM
1FastBrick's Avatar
Custm2500's Rude Friend
Positive battery cable Junction box.
Old Jul 30, 2016 | 03:01 PM
Gracias
Old Jul 30, 2016 | 11:10 PM
1FastBrick's Avatar
Item #10 15321247 CABLE. Battery (Positive)
Item #11 12191376 BLOCK. Battery. (Positive)
Item #12 19116063 NUT. Battery Cable.
Item #1 15321206 or 15321209 CABLE. Battery. Chassis Wiring. (Positive)
15321209 CABLE,GEN(286MM LG)(FUSIBLE LINK)
15321206 CABLE,GEN(812.8MM LG)
Old Aug 5, 2016 | 08:11 AM
midnightbluS10's Avatar
Personally, I would be running a bunch of accessories off of that post if it were me. I'd give them dedicated power sources or wire directly to battery positive.
Old Aug 5, 2016 | 10:18 AM
that post is basically dedicated power. + battery post goes directly to that block. and the alternator feeds back directly through that block.
D1SCSS
Aug 29, 2016 11:21 PM
Flewbyu123
Mar 16, 2016 09:29 PM
Bluecollar Hotrods
13
Mar 8, 2016 09:39 AM
tim wellington
Mar 1, 2016 10:11 PM
