My WOT Efi live log
#61
#62
Lol uh oh. Well it is a Flex Fuel VIN.
I guess I just dont understand why the stock PCM that came with the engine is giving you issues. If the harness, PCM, engine are all out of the same truck it should work fine. You said your truck was a FF truck originally so even that part shouldn't be an issue.
What exactly is wrong with the way it runs? Or is it just your logs making you think something is up? (and you feel that it runs fine)
#64
That tune is gonna have non-flex injectors scaled in. So it probably won't run well. Stock non-flex are 24# and flex are 38# (or something close to that)
#65
Its not its working fine now, the only thing is that it was commanding like 9 on my a/f but i switched that and now is commanding 14. I only have one oxygen sensor working so that could be why. Ill be getting everything replaced and a widebandIn this Thread you said it wasn't out of an avalanche, but a tahoe?
Yay for 38# injectors!
#67
#68
Yes 4. The 2 before the cats are the most important as they determine your fuel trims. The 2 after the cats are there to determine if the cats are working. Most people remove their cats and turn those O2's off in the tune so the don't trip the SES light. The 2 up front NEED to be working.
#69
#70
It would not run well but, I think it would still run, ...and throw codes.
Get those O2's fixed and then delete all your long term fuel trims in the tune and reload. There is probably a tutorial on how to do that on the EFI site, or maybe on here if you look around.
