mixing gas
Don't know the truth of this but I read somewhere that 2 different octanes will not mix.
So if you have a quarter tank of the cheap stuff on the bottom then add top the tank with the good stuff, you won't you wont be burnin the higher octane untill you burn the **** first.
The 2 will mix fine.... that would be like saying bottled water, and tap water wouldnt mix... they are chemically so close to being the same.... and you are pretty close if not spot on for it being middle of the road numbers
