missing under load, backfires, popping
Old Oct 10, 2011 | 08:26 PM
  #121
03sierraslt's Avatar
Good to hear Josh, if thats the case bring it to the flashlight drags near my house at Beaverrun this coming Sat.
Old Oct 12, 2011 | 11:00 PM
  #122
Littlewaco's Avatar
Registered User
I've got the same problem pretty much other than my truck is basically stock other than my trucks only mods are diablo programmer, cold air intake and exhaust nothing major. Should I look at checking the same things you have or what? My truck jus started this last week and it is getting worse everyday I even went back to stock tune. Anything I should check first? Truck has 145000 miles.
Old Oct 13, 2011 | 08:56 AM
  #123
Holty's Avatar
Notorious BIG
I doubt it is stock valve springs that are your problem. First place i would check is for spark plugs, wires, and clogged cats. You'll likely find your problem.
Old Oct 13, 2011 | 10:30 AM
  #124
Littlewaco's Avatar
Registered User
Ok I will check that truck had new plugs put in right b4 I purchased it but he didn't put new wires. He said he put the g3 plugs in it which I really dont like. I've also had codes pop up this morning po300 po449 po455. I'm back to running factory tune for that reason because some things were turned off on performance tune
Old Oct 13, 2011 | 11:20 AM
  #125
I would ditch those plugs and put a standard plug in it, replace the wires and check cats like holty said.
Old Oct 13, 2011 | 11:21 AM
  #126
Po300 is misfire, the other two are related to the evap purge system
Old Oct 13, 2011 | 05:49 PM
  #127
Littlewaco's Avatar
Registered User
so go to just a regular plug not anything else?
Old Feb 2, 2021 | 06:33 PM
  #128
Dave Hofstra's Avatar
Registered User
Originally Posted by Holty
Ok, well, the verdict is in (kinda) lol.
I think the problem was the valve springs. I took the time this weekend and finally changed them out even though i was pretty sure it was not going to fix the problem seeing that visually, the comp 918's (new version) looked fine. I broke down and bought a set of PRC double springs that cost me right around $300 with shipping. After my wife royally chewed my *** out about spending the money i decided if this did not fix it i was going to throw in the towel for this season. Anyways, i spent the a couple hours on sat and the majority of the day sunday swapping them out. Didn't run into any problems at all, the hardest part was getting the air compressor adaptor/fitting screwed into the spark plug holes. Didn't even drop a single "keeper". Below are a few pics i took, not really sure why i took them, but you can see the difference between old springs and the new ones. Although, the old springs are really not that old, less than 10k miles on them.
Went out for a test drive after letting it warm up a few mins. FIrst thing i noticed is that these new springs are LOUD. MUCH louder than the comps. I drove around easy for about 10mins or so than eased into the throttle. No misfire. Went into the throttle a little harder, still no misfire. I took it WOT up to about 120MPH letting is shift through the gears. NO MISFIRE.
I don't know what to say here. I'm pretty disappointed in the comp springs at this point. My cam is not big by any means and these springs should have been fine. I'm still not convinced that fixed ALL my problems though.
I still have a top-end hesitation that has been there ever since my truck was rebuilt back in 2008. Its very slight and hardly notieable by anyone other than me, but i'm certains its adding a tenth or two off my 1/4 mile times. I always used to think it was a fuel pressure issue. But thats not the case
Anyways i'm happy for now and the truck seems to be running well. Now time to start troubleshooting my N20 that has been installed for two years and has yet to work lol.
Attachment 143569
Attachment 143570
Attachment 143571
I have to say thank you because I'm 1000 in and I think you just solved my problem!!!
zeake
40
Nov 23, 2015 04:41 PM
BlackGMC
27
Sep 28, 2015 11:05 PM
smokeshow
141
Jan 6, 2013 05:12 PM
sprayedenali
Nov 10, 2012 09:48 AM
FL-Pirate
Jun 16, 2008 09:00 PM
