miss fire
Old Jun 4, 2009 | 11:09 PM
nicky g's Avatar
Default miss fire
Has anyone had a problem with their engine after tuning the computer?
I seems to get worse when the a/c is on..... but when im just driving around with the rpms up it doesnt do it. Any opinions with cause of my problems. Im thinking its a coil problem or maybe a lifter problem. Hopefully someone can also tell me some tricks to find out what the cause of it is.
Old Jun 4, 2009 | 11:25 PM
nicky g's Avatar
went from the aftermarket to the stock spark plug wires to see if any change but nothing it still does the same thing..... it sounds like a mis but only when im at stand still like at a red light or a stop sign.
Old Jun 4, 2009 | 11:32 PM
Wilde Racing's Avatar
How do I change this text
New plugs? Does the check engine light flash? if so Autozone will read codes for free. That would be a start. next depending on answers would lead to moving coils plugs and injectors around to see if the misfire moves too, But first we (you) need to see if it is a random misfire or a cylinder specific...
Old Jun 5, 2009 | 09:33 AM
droppedchev's Avatar
im having the same problem it only does it when its idling i changed the plugs wires everything idk what it is the check engine blinks when it does it
Old Jun 5, 2009 | 01:22 PM
lucky77's Avatar
Banned
mine did it 2 . . .after a tune. some people say cus of the DOD lifters other say DOD injectors...check out the codes , to see if its random misfires
Old Jun 5, 2009 | 04:55 PM
nicky g's Avatar
well i checked with my friend that tunes and it didnt pull any codes and then i changed the plugs and the wires and still the same thing
Old Jun 5, 2009 | 08:22 PM
yea mine doesnt throw any codes i changed the plugs and wires to i was lookng at it today and i had like 4 intake bolts that werent even tight i tighten them and it did it once for like 5 seconds and hasnt done it yet so far so hopfully that fixed it
Old Jun 5, 2009 | 08:32 PM
if no codes, it could be fueling related...
Old Jun 5, 2009 | 10:32 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
When it was "tuned", were the engine mis-fire diagnostics parameters changed? The pcm may be ignoring the mis-fires because the count isn't high enough to trigger the code.
Old Jun 6, 2009 | 06:10 AM
im not sure if it was changed i can ask my buddy if it was but it never did it with my other motor in so i dont see how its a fuel problem unless one of the injectors is dirty
