Max timing issue. I'm at a loss.
Old Nov 17, 2007 | 03:12 PM
TurboGibbs's Avatar
See, you can teach and dumbass something. Thanks.
Old Nov 18, 2007 | 05:14 PM
Zick's Avatar
Originally Posted by TurboGibbs
well, the forum doesn't like the config file. not compatible i don't guess.
You can just rename the file extension to something like *.doc and upload it. Then whoever downloads its to look at it will have to rename it back to the correct ending extension.
Old Nov 30, 2007 | 03:25 PM
TurboGibbs's Avatar
Sorry to bring this up again but I have one more question.
Is there any way to accurately log timing and use the info in the editor? Is there any way to make your hi/lo oct tables reference rpm vs kpa instead of rpm vs g/cyl?
Old Nov 30, 2007 | 05:53 PM
03sierraslt's Avatar
Hmm, I dont think but I really cant answer that... Maybe foff will chime in..
Old Nov 30, 2007 | 10:47 PM
foff667's Avatar
LS1TECH Sponsor
Theres 1000 different ways to do what you want using histograms, it really depends WHAT YOU WANT. The #1 & #2 default histograms are good starting points, using filters & such are another.
No, the stock pcm maps it again g/cyl not against the map sensor.
Old Dec 1, 2007 | 04:01 PM
TurboGibbs's Avatar
Ok, enough with beating around the bush, This is WHAT I WANT. Can you show/tell me 1 way that I can log timing and be able to use that information accurately, directly or indirectly, in the hi or lo oct. table in editor while in Speed Density?
Old Dec 2, 2007 | 02:59 PM
TurboGibbs's Avatar
Every time I change the x axis in the histogram away from g/cyl all it will show is one cell in the upper left hand corner.
Correction, I can change x to kpa and the table does well. But that does me little good.
ferrellrooster
Mar 6, 2025 03:22 PM
Oobray
Jun 13, 2022 03:38 AM
97aztecgt
Aug 13, 2015 02:11 PM
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
