MAP calibration EFIlive
I went with a 2 bar map on a COS tune and I am having problems calibrating the map.
Since its a 2 bar map C6301 Map Sensor Scaler should be set to 190 right?
Then C6302 Map Sensor Offset should be set to a number that makes it read proper barometric pressure whit the key on engine off?
I set C6301 to 190 then played with the scaler to make it read proper barometric pressure for where I am. I then hooked up a vacuum pump and gauge to the MAP and pulled vacuum in steps to make sure the MAP would read right through its range and its way off...
Any suggestions?
Any suggestions?
You need to leave B6302 alone! You set B6310 to 190 for starters, and then adjust it to make the KOEO read the same kpa as you stock 1 bar read with the KOEO...
Do not adjust B6302!
calsdad
Jun 14, 2023 11:07 PM
Tydriver
45
Oct 23, 2015 09:19 PM
supershift67
Sep 18, 2015 08:21 PM
