MAF Tuning in SD- Way Lean when coasting or braking
MAF Tuning in Open Loop - Way Lean when coasting or braking
Edit: the title should say Open Loop not SD....
Well I got my VE table dialed in with in 1% so I decided to reenable my MAF to tune it via BEN correction. Everytime I would take my foot off the gas it would go way lean (18+) in the lower MAF Hz ranges. I would apply the BEN correction and it reflash then it would do the exact same thing. I have done this same process before my headers and new exhaust setup. I also put my WB after the Y pipe so it is farther down stream, previously it was next to the first factory O2 sensor... I don't think I have any exhaust leaks, do you think the placement of the WB is the problem? Attached is my tune and loggs.
AutoVE-002_0003 = MAF Disabled, AutoVE tune
AutoVE-002_0004 = MAF Enabled
Log_0003 = MAF Enabled Log...
Any help would be great!!!!
Between 2375 and 4000. For example, It will idle just fine not problems, a little lean or a little rich, then I go drive same thing a little lean or a little rich, as to be expected from an untuned MAF table. But when I am at speed say 60 and I left off the throttle complete and let it coast or I hit the brakes the AFR goes to 18+. then after a little bit it will return to normal....
One thing I did read is that ram air may cause this. I have a ram air tube in the tow hook position and the other end is pointed directly at the MAF (stock air box with K&N)...
Well I am going to try something different that DC_Justin suggested that I finally got to work. I am going to log DynAir while OpenLoop no MAF and get the MAF values. I tried it early but, I did not have the column width wide enought to see that the hundreth or tenths digit, (I know I am retarded) so I thought I was only getting single digits.... I will report back my findings...
SLOPONY
20
10-18-2016 06:05 AM
05GMC4.8
08-07-2015 09:55 PM
