Maf to speed sd
Old Feb 26, 2016 | 10:59 AM
VETTEKILR53's Avatar
Default Maf to speed sd
Have everything i need to convert my 2013 5.3 to SD. just need to know where to run the 2 wires for the IAT sensor. i looked through as many posts as i could before getting a headache, so i will just ask.
TIA
Scott
Old Feb 26, 2016 | 12:04 PM
George C....'s Avatar
Formerly ScreamingL
2013 doesnt need to be speed density, stock maf will support all power youre on3 turbo kit wil make
Old Feb 26, 2016 | 12:28 PM
Still doing the conversion. only running the on3 turbo for a week or so and going bigger. Tuner and I decided that SD is the way to go for what the end goal is.
Old Feb 26, 2016 | 01:39 PM
Vortec350ss's Avatar
I would probably go to 2 bar and dial in the VE but continue to leave the MAF. It will run better.
Old Feb 26, 2016 | 02:28 PM
Formerly ScreamingL
E38 pcm isnt same aminal as 411
Old Feb 26, 2016 | 03:02 PM
UnVmy5.3's Avatar
George is 100% correct....
Old Feb 26, 2016 | 03:12 PM
Yea I know, but can't you tune the VE table with EFI Live?
Old Feb 27, 2016 | 11:32 AM
OK, going back to MAF. problem is the BOV is post MAF now. goung to make a new pipe with the BOV pre MAF and roll with it. Thanks for all the input guys
Old Feb 27, 2016 | 12:40 PM
Formerly ScreamingL
make sure BOV is a good distance from Maf
Make sure maf is on a nice piece of straight, good distance after and before a bend or youll have issues
also toss the maf in a 4" tube for the most range, 3.5" works but is limited vs 4"
Old Apr 8, 2016 | 08:30 AM
SSnation's Avatar
Are you referring to the coefficents I'm assuming?
