MAF reading zero
Old Feb 18, 2016 | 03:49 PM
crashmymax's Avatar
Default MAF reading zero
Just installed Trick stage 2 kit on my 09 Silverado. Its at the tuner now but the computer is only getting a zero from the MAF. using his HP tuner and my diablo i2 both read zero. Tuner does not have time to track down the problem any ideas on what could cause this? I did not cut any wires to move the MAF and I just went down there and unloomed everything and checked for broken or stretched wires. everything looks good.
Old Feb 18, 2016 | 04:10 PM
George C....'s Avatar
Formerly ScreamingL
Is maf properly plugged in?
Did installer of maf break it by any chance
Its 3 wires
Ground
5v
Signal
Old Feb 18, 2016 | 05:03 PM
crashmymax's Avatar
Its 3 wires
Ground
5v
Signal
Your helping me on the forced injection area to. I did not damage it when reinstalling it. Is there a way to tell if its damaged? Do you happen to know what 3 wires are for the MAF? thanks for helping
Old Feb 18, 2016 | 05:12 PM
Formerly ScreamingL
Black
Pink
White or light color
Tan .....iat
Tan with black...iat
Should be able to view it with eyes but you would get a code
Formerly ScreamingL
Unless running maf doesnt read
Old Feb 18, 2016 | 06:16 PM
JordanH's Avatar
Restricted
Which maf are you running?
Old Feb 18, 2016 | 08:29 PM
crashmymax's Avatar
my factory MAF
Old Feb 18, 2016 | 10:40 PM
Its 3 wires
Ground
5v
Signal
It's 5 wire, not 3. It is 12V not 5V.
Check the 15A ENG fuse. Check Ground G103. It is item 4 in the engine pic.
If your tuner can't/won't figure out a simple problem like that I would be getting my vehicle away from him and to someone else.
Attached Thumbnails MAF reading zero-09-maf.jpg   MAF reading zero-09-maf-g103.jpg
Old Feb 18, 2016 | 10:52 PM
Formerly ScreamingL
Maf is not 5 wires.....its 3 wires with IAT being the other 2
Got me on the power to maf is 12v but signal is 5v from pcm
Old Feb 18, 2016 | 11:48 PM
How many wires are on the plug?
