MAF question
Old Aug 14, 2009 | 04:55 PM
outlawz2004's Avatar
Default MAF question
Needing a new one. I had an extra sitting around for a long time and got rid of it, now needing a new one. Mine is acting up lately. I have one from a 98 laying around, that one wouldnt work on my 04 would it? I quess I will have to visit the pull a part and look for one unless someone here has an extra one around.
Old Aug 14, 2009 | 04:57 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
What makes you suspect you need a new MAF? Have you tried cleaning it?
Old Aug 14, 2009 | 05:14 PM
Having idle problems that started a few days ago. Cleaned the maf and throttle body, that afternoon CEL came on. Had the codes read, lean on banks 1 and 2. Recleaned the Maf, CEL went off last night when I left work. This morning, no CEL. Then around noon, truck idle problem came back and light came back on. Seems to be having this problem in the heat of the day, but when its cool out it runs fine. I put gas at a place I normally dont the other day and the stuff didnt really even smell like gasoline. I figure the MAF is causing me problems causing the truck to run lean and idle low. I am going to also check the plugs and o2 sensors tommorow. Plugs have 30,000 on them.
Old Aug 14, 2009 | 09:52 PM
Anyone think I am on the wrong track here thinking its the MAF?
Old Aug 14, 2009 | 10:56 PM
tk-mpl's Avatar
check for a broken wire at the maf sensor connector. Could be possibly broken inside the insulation
Old Aug 14, 2009 | 11:28 PM
Wheatley's Avatar
Truck Sponsor
A bad MAF could cause this yes.
Have you pulled the code to see what it comes up with?
no sir a 98 truck MAF will not work on the LS trucks.
Old Aug 14, 2009 | 11:34 PM
Yeah, I have the print out in my truck. I will post them tommorow, I am currently at work.
Old Aug 15, 2009 | 11:46 AM
UPDATE: Got up this morning and pulled the plugs. They had a little carbon on them, but not bad and the color was good on them. Pulled the K&N intake off, recleaned the MAF real good, cleaned the throttle body again also. Cleaned and oiled the airfilter. Pulled the o2s, they had a lot of carbon on them, possibly from the seafoam treatment. Cleaned them and started the truck. Idle was much better, ran smooth. Let it run about 5 minutes and the light went off. So it was either the MAF, or the o2s. I will see how its running on the way to work this afternoon.
Old Aug 15, 2009 | 06:37 PM
Well, ran great on the way to work, no lights either.Yay.lol
Old Aug 15, 2009 | 06:57 PM
Wheatley's Avatar
Truck Sponsor
Good deal.I am not sure how many miles you have on the truck,but if you have over 100,000 miles it never hurts to go ahead and relplace the front o2's,alot of people may not but it never hurts,thats for sure.Even if they are not lazy yet,I still replace them
